mrcleeaan
- Jul 26, 2019
- Genesis G70
Here is the fix I did to mine... I had initially tried some honda shin etsu grease around the seals, it didn't work. Saw the post by Revvdmedia about the stinger sunroof rattle fix and tried something similar.
There is a notch on both sides of the tracks that the sunroof goes into, this is towards the front of the sunroof opening right behind the windscreen. In the picture below, I believe the stinger forums mentioned putting something down in the area I circled in blue, instead I ended up using some foam tape (pic below) and stuck it in the area I circled in red (after cleaning it really good with rubbing alcohol). No more rattling ever since. Hope it works for some of you.
