Is that 12.07 with rwd or awd?
Awesome!!!!!! How I can get mine there when it cools off. We have a drag night in December but it’s still in the 70s here for now
Added JB4 and used Map 3 = 3.8 to 60mph and 8.2 to 100mph.
(I ran a 4.1 and 8.8 on a less grippy stretch of road)
Interesting. You're more than a full second quicker to 100 than a M340i. You can confidently run a stock M340i. i don't think anyone has been able to crack bmw's ecu
What are you running for gas on map 3? Boostane or e85? Or race gas?
As close to E30 blend as I can
I get it down to empty (5-10 miles till empty) then add 9 gallons of 93 octane and 3.25 gallons of E85
I've done this the last three fill-ups so should be pretty solid E29-E30 blend at this point.
anyone with a 2.0t?
Not exactly what I was hoping for but best stats my car has gotten yet. Had a bit a wheel hop all the way through first gear so I feel a better et is just a matter of time and getting the correct launch figured out. Track was at 2000 ft elevation and da was 3600ish Temp was 55 degrees and tons of cars so not being able to do a burn out hurt a lot when you have to wait almost two hours for a pass
Remind me what you have on your car in terms of mods.... Also, RWD, right?
A 12 second car is pretty dang fast.
Ya rwd. Jb4 Bms intakes. Ark midpipes. Jun bl racing cat back
yep pretty quick. My best was 12.57 @ 113.83 that’s with Rwd and JB4 only on map 3 with BOOSTane. Figuring out the launch 🚀 is key. I didn’t use launch control and short shifted 1 at 5200.
I’m thinking if I actually get traction on a launch and don’t hop I can be close to that. Hoping at least
BANG! i already knew just riding in the car.
So I take it no one has tried the brake switch mod on the genesis side of the car? Seen a lot of stingers with it but not many rwd ones.
well i think i might be the first g70 owner with the burger burnout switch. needless to say i can smoke the tires instantly now going testing with a few buddies this weekend will report back on if this helps get the launch nailed since i can properly warm up the tires now.
So you cut the wire by the ECU? Or did you figure out a different way?
