Is that 12.07 with rwd or awd?
Awesome!!!!!! How I can get mine there when it cools off. We have a drag night in December but it’s still in the 70s here for now
Added JB4 and used Map 3 = 3.8 to 60mph and 8.2 to 100mph.
(I ran a 4.1 and 8.8 on a less grippy stretch of road)
What are you running for gas on map 3? Boostane or e85? Or race gas?
As close to E30 blend as I canWhat are you running for gas on map 3? Boostane or e85? Or race gas?
Not exactly what I was hoping for but best stats my car has gotten yet. Had a bit a wheel hop all the way through first gear so I feel a better et is just a matter of time and getting the correct launch figured out. Track was at 2000 ft elevation and da was 3600ish Temp was 55 degrees and tons of cars so not being able to do a burn out hurt a lot when you have to wait almost two hours for a pass
Ya rwd. Jb4 Bms intakes. Ark midpipes. Jun bl racing cat back
I’m thinking if I actually get traction on a launch and don’t hop I can be close to that. Hoping at leastyep pretty quick. My best was 12.57 @ 113.83 that’s with Rwd and JB4 only on map 3 with BOOSTane. Figuring out the launchis key. I didn’t use launch control and short shifted 1 at 5200.
BANG! i already knew just riding in the car.Not exactly what I was hoping for but best stats my car has gotten yet. Had a bit a wheel hop all the way through first gear so I feel a better et is just a matter of time and getting the correct launch figured out. Track was at 2000 ft elevation and da was 3600ish Temp was 55 degrees and tons of cars so not being able to do a burn out hurt a lot when you have to wait almost two hours for a pass
When we gonna send the 2.0 down the track?BANG! i already knew just riding in the car.
let me get some miles on her first break her inWhen we gonna send the 2.0 down the track?
So you cut the wire by the ECU? Or did you figure out a different way?well i think i might be the first g70 owner with the burger burnout switch. needless to say i can smoke the tires instantly now going testing with a few buddies this weekend will report back on if this helps get the launch nailed since i can properly warm up the tires now.
cut and spliced in a switchSo you cut the wire by the ECU? Or did you figure out a different way?
