The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Genesis parts & accessories
Advertise with us!
Advertise with us!
How did you go from looking at buying a small, two seat roadster (a convertible) to a 3900 lb four door sedan (i.e. NOT a Sports Car)?
Nice! I've never driven a Miata, but I think it would be a blast. Might be a bit tight for me. The real test is which keys do you reach for when going out for a drive? (Obviously the G70 is the choice when taking other people or hauling luggage, etc..)I have both-NB Miata and G70.
Are you sure you have that option turned on? that the easy access seat setting is set correctly?Seat extension for easier access does not work too. I put it extended but never worked. I'm only 5'10. The function worked in my Stinger though with the same seat position.
What and how the Stinger does, doesn’t mean Genesis will be exactly the same. Genesis may have slightly altered shift points or programming logic. The seat retract issue has been talked about before. Once the seat is in a certain position, say 70-80% of rear extension, the auto retract function doesn’t work. Not sure why? One work around is to program seat position button 2 to full rear extended position. When you stop, hit button 2 and retract back, problem solved.Today I was driving using paddle shifters but not in a sporty manner. Using below 3500 rpm. And, my car did not shift up to 7th when the rpm was 2500. I tapped my paddle shifter multiple times and did not work. I pressed and held + for few seconds for automatic mode and finally it shifted up to 7th. Never had the issue with my previous car Kia Stinger.
