I just did this. I wanted to give anyone instructions with a V8 on how to go about changing out their amber DRLs to LEDs.
I did have to re-pin the driver side socket. It was a pain but doable.
I purchased these from Amazon per another users post.
Step 1: Remove radiator clips and cover. Set aside.
Step 2: Remove brace that runs over top of each air-box cleaner. I think it is a 12mm.
Step 3: Remove clips that hold top of air-box on
Step 4: Loosen the hose clamp that hold the intake pipe to the air-box. It should be a 10mm.
Step 5: Remove top of air box
Step 6: Remove the two screws that hold the bottom air-box in place. Remove bottom air-box.
This should give you pretty good access to the back of the headlight assembly.
Step 7: Remove dust cover on back of headlight assembly housing.
Step 8: Remove bulb and place aside.
Step 9: Place new bulb in socket
Reverse assemble.
IF you need to re-pin I will explain how I did it.
Below are photos of the connector that need to be re-pinned
This connector is held on to the head light assembly.
Remove the bottom of the connector tab with a screw driver. You will need to put some force on it. I used one finger behind the connector to keep it from bending and using your other hand with a screw driver push the tab to release the clip.
Once you have the bottom of the plug removed. Bend the connector down towards the ground. The metal tab holding it is pretty forgiving.
Slide a flat head screw driver between the connector and the metal tab. The connector should release downward towards the bottom of the car.
You should now have a socket and connector.
Mark one of the wires and on side of the connector before you disassemble.
Looking at the connector where the wires go into it there is a little cover back where the wires come out of it. Using a small screw driver pry that access cover off. You should now see down into the connector where the wires meet the prongs.
Look down inside the connector / prong and you will see a small white tab. That tab is holding the prong inside the connector. Find something small to push on that white tab and pull the prong from the connector.
Reverse the wire locations and reassemble.
Test your new socket on the vehicle before putting it all back together.
I put the connector back onto the metal tab and bent it back into place before hooking the connector back to the plug.
I can't speak to longevity of these LEDs as I just put them in but they seem solid.
On the plus side this does not affect you from going back to incandescent bulbs. LEDs are particular about polarity while incandesant dont seem to care.
The car does not hyperflash and so far I am pleased.
