There is another thread here somewhere, where the issue of the amber DRL/turn signal bulb burning out is an issue. Seems some folks have been chasing this problem, replacing the bulb multiple times. Just wanted to let you all know, it happened to me last week. I called the dealer, and they said it was a known issue. There is apparently something wrong with the wiring harness, which causes a short & the bulb burns out. They replaced the harness & bulb under warranty. I did ask if they could be pro-active and go ahead and replace the harness on the side that had not burned out. Was told, "no", the bulb would have to have burned out. But if it does, bring it back for the free fix. Sooooo, just FYI, if you're one of the folks having this happen, the next time it does, it's covered ( provided you're still under warranty ).
