Artie Shane
SUSTAINING MEMBER
- Nov 24, 2022
- Location
- Bay Area, California
- Genesis Model Year
- 2023
- Genesis GV60
Great to know, as this is a point of failure that I'd rather not experience.Wouldn't that make him fee older? We are Samsung here only. I was over the iphone in 08. The part number for the USB port has NOT changed according to my parts dealer and is readily available. My cost was $100.75. This is for those with hardware connection issues.
On a separate note I did have my shifter start glitching a couple days ago. I took it out and thoroughly cleaned it and looked for the hi chew wrapper I THOUGHT i had dropped in there a while back. Well there was no wrapper. It was the ribbon that connects the shifter to the base. It was rubbing on the shifter every time I started and stopped the car. Eventually the connections started to fail. I had it repaired locally at a computer repair place and he did a marvelous job. All 30 pins were extended and they protected it and taped it down to avoid any further contact. If you ever hear crumpling wrapper sounds make sure to remove (it's one screw and the entire panel pops off with 3 harnesses to unclip). CAREFULLY tape the ribbon down so as to avoid having same issue I did and reassemble
Any images of the work...?
