The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Genesis parts & accessories
Advertise with us!
Advertise with us!
Hi - Is it advisable to remove the metal wire surround "spring" from the origional wheel cap before heating it in the oven? Thanks!
Drive a brand new 2011 Genesis 4.6 V8. Have secured the winged emblems to replace the oem center H, but cannot figure out how to remove the center wheel cap so I can heat it, remove the H and replace that with the winged emblem. When I put a screw driver in the slot and try to pry off the cap it seems to stick and am afraid I will bend it if I use too much force. What am I doing wrong? Can't find anything in the manual regarding removal.
Thanks. Some tape on the screwdriver and a little more pressure did the trick.
Now that I have the center wheel caps removed from the car am I supposed to put them in the oven, per other instructions, so the center caps that the original oem H are attached to can be removed (popped out) ? If so, do I then "peel off the original oem H plates and replace them with the winged Genesis plates that have 3 M adhesive on them ( I purchased them on e bay) and, finally, replace the newly designed center cap to the wheel caps and reinstall on the wheels?
Just completed the transfer process. Used an oven at 225 degrees for 15 minutes to heat each 18" wheel cap. Then, I gently pried off the oem center H logo from their bases using small knife and screwdriver blades as the pry tools. The multi-pronged bases for the oem H logos never popped out of the wheel caps, as expected. The thin gripping rims of the oem H logos were not even damaged during the process. ( I'll keep them as souvenirs.) I then placed the purchased wings with 3 M tape backing directly onto the thin, sticky, putty-like substances that remained unmoved on the surface where the oem H had originally rested. The purchased wings were slightly smaller in diameter than the oem H logos, so I was careful to center them on the top of the original bases. They look great! Thanks to all for your advice and support pictures.
