skipgen
- Jan 17, 2019
Wow!LOL. I was just about to install my upper oil pan until I realize that I will need to clean the cylinder heads for the upper timing covers. The problem would have been that the old RTV could have fell into the upper oil with no way to clean it out without pulling the pan again.
If I clean the cylinder heads first then most of the old RTV would just fall out the bottom of the lower timing cover; especially if I use compressed air. Therefore, I will clean and install the upper timing covers before installing the upper oil pan.
I will take pictures of the RTV bead I will lay this time before installing the upper timing covers.
My upper timing covers that need to be cleaned and installed.
Sure did bite off a mouthful! But might as well do it right while you're in there....
