Sebastian4k
- Sep 22, 2019
- Genesis G70
Plug it in man and send results! Only took me 20 mins to installLet’s continue the saga
results same as yours.
The amp is actually not receiving the correct commands. It’s remaining asleep. I was able to briefly wake it up with GDS for a diagnostic run and it passed music...for about 3 seconds. MOST ring is good the whole way around.
this newer unit is running MeeGo still. Just different firmware inside. Hardware is looking the same.
sounds like that means Hyundai intentionally decided not to allow the higher end units to be upgraded
Man... that's turning into a full blown hack!If I knew what I was doing I could bring Carplay to the older head units. I'm going to attempt booting from the newer head unit's drive to see what happens on the old head unit.
Great research!results same as yours.
This is getting interesting again... lol... if the old deck boots with the newer SSD then it's just a matter of imaging the SSD with the newer firmware. I don't know how the newer firmware is going to talk to the old amp though.
I found some CANbus mappings that may be the issue.
This seems like the most user-friendly route, though the big hurdle is the "Authentication Code" they generate that locks the sd card to your vehicle. Previous threads found it's likely writing it to the SD card's CID/serial number, which adds some complexity. The head unit verifies the auth code mapnsoft generates, even in older vehicles where you had to type it in manually, so I'm sure it's not "phoning home" and is probably just some hash combination of the VIN and Device ID (those used to be the only 2 requirements, though now their online form asks for model code and map version). We do have access to the head unit files now, so perhaps we can find the method of authenticating the SD card. Even if the auth code could be replicated or bypassed, I'm not sure if anyone still has the old sd update for people to tinker with.Hey it’s me again. New idea.. how about getting a 2017/2018 sd card update and potentially getting ACP through that method..? Or maybe buying NavTool interface?
Yeah... Comparing the two would be helpful in finding what's changed with the amplifier/canbus mappings Suburbazine mentioned. I imagine modifying the 2018 head unit files to get the amp working is the easiest route, given things seemed to work out of the box with the 2018 aside from sound. I'll try to pull my 2016's SSD out this weekend and see if I can compare with the files posted previously for any clues.I wonder what would happen if we copied over the CarPlay app files from the newer unit to the 2015/2016 unit's hard drive file structure? If we get an image of both hard drives a comparison could be completed to see differences and uniques to possible piece in the files needed while leaving the settings/files needed for amp to work unchanged
What VM environment are you going to be using so I can have it already installed.
I built the images in Ubuntu using gnome-disk-utility, they will be a .img file. I'm not sure what environment to use to launch it, I've been trying to get VMware Workstation to start it but haven't hit upon the magic combination yet. Getting the 2018 image compressed now, nothing is fast about a 128gb file or even whatever it shrinks to. No alteration or washing of the partitions has been performed.
