Superdarkcheeze
- Apr 20, 2021
- Genesis Model Year
- 2013
The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Genesis parts & accessories
Advertise with us!
Advertise with us!
Probably carbon buildup on the heads and valves. Might be worth getting it cleaned. You should get better performance, too.Speaking of high mileage Genesis, does this car maintain relatively the same gas mileage as when it was new? Or it gradually got worse for you folks?
My 2005 Nissan Altima v6 gradually got worse gas mileage!!! It's 16mpg at 170k miles vs 22 when new.
Shady, you've got me by about 15k. My 2011 4.6 has about 206k. It's my commuter car and ok on the daily 70 mile roundtrip, but I wouldn't venture much further. Check engine light has been on for about 3 yrs. Two mechanics and my tester say catalytic converters. One quote was $4k so not happening. A couple cans of magic juice turned the light off 2 yrs ago and I made it through NJ inspection. That didn't work this past April though. Engine seems strong and never a sulfur smell, buts it's near end of life. Trans has been flakey for at least 100k even after a flush and filter change.
I have a 5L Genesis G90 and I can't say that I notice that it is louder than the 4.6. Probably a lot better cabin soundproofing in the G90 so not a fair comparison. Hope the G90 lasts as long!
did you flush the transmission? is this the 5.0 version?2014 Genesis with 192,800 miles.
Drained and flushed and serviced by the dealer at 86K miles. Searching for a new pan/filter combination for the next maintenance event. It has the ZF 8 speed but evidently there are two different series for the 2014 3.8 vehicles. Had the differential done as well and that will done again when the trans work is accomplished.did you flush the transmission? is this the 5.0 version?
Gotcha. My owner's manual said to drain and service at 100K(that's when the warranty stopped) so I did mine early and no issues now at 192,900. Smooth shifting just like brand new. I previously owned a 2006 V6 Sonata with similar service requirements. Had the transmission drained and serviced at 76,000 miles then at 82,000 miles something happened and the transmission was bucking and acting up. Dealer asked if I used the manual shift gate as that seemed to be causing the issues. I told him no and that I had traded a manual gearbox car in for the automatic. Additionally, I said the car was new with the manual shift option so it didn't make a difference. New transmission installed and I never did another thing to it. Traded it with 255,000 miles for the 2014 Genesis I own now.my 4.6 trans is bulletproof I would say, never flush or anything, a little rough shifting on cold days but nothing like a misshift. I'm scare to touch my 5.0 trans.
I think your car use a genesis transmission its not a zf.My Genesis is the V6, 3.8L. Door tag shows October 21 2013 date but sold and registered as a 2014.
Will have to check into it. Will advise when I figure it out.I think your car use a genesis transmission its not a zf.
You are correct.I think your car use a genesis transmission its not a zf.
