OneFunGenesis
<- Runnin' on Empty
^ I have had this happen in a different way. When this happens to me, the car slams into gear, then hesitates while it decides if the gear is right. Then takes off like bat from hell
I have further modified the flapper and removed the magnet from the flapping part. There is a improvement in every day driving, but there is still a lag when slowing down (40 to 5) and hitting the gas to merge into traffic.
Better, but still not ideal.
I will try to do this and get back to this thread, though I'm not sure when I'll be able to find an open road to be safe.
If I leave it in manual mode, there really isn't a lag because there isn't any gear hunting. Throttle response is as close to immediate as drive by wire can be.
Question about program training: You mention ~200 miles to train. Does the training eventually "wear off" over time if I then leave it in full auto for the next 2,000 miles? Or does it retain the training virtually forever?
is every 50 miles or so, is to drive the car like I stole it for at least 5 miles or so
I just took mine out by removing the screw and pulls right out as far as response I like it better no hesitation at minimum throttle or full throttle
Let us know if it affects the mileage.. Some debate and experiences in here doing this lowers mileage.. I would like to know.. I am, suspecting that maybe those who experience lower MPG, might be taking advantage with their slight lead foot, the better response..
30mph to 0mph or maybe 30mph down to a rolling 1-3mph then flooring it. There's always at least a 2 second delay if I go from 30-0 hard on the brakes. The car acts like it's confused.
I'm sure it would do the same thing if I was going faster though. The computer must be programmed to assume that someone who's stopping quick isn't going to take off fast so it lets the transmission leisurely shift down to first.
The fix is not to floor it. Instead, apply gradually increasing pressure to the gas pedal.
Do you know how hard it is NOT to floor it in a Genesis?!?!?!?![]()
