genesis@genesisworld.com
Weeeeeeeellllllll... I I got it installed, and it wasn't pretty. I opened up the sheath of the harness and easily identified a negative wire for ground. That took 10 minutes. I spent the next 2.5 hours trying to find a wire that provided 12vdc when the door is open then zero when it is shut. I never found one. By the way, there are 2 fiber optic cables running in that harness !
So..... I went to the bench to see just how much the light in the sill draws. Answer is .007 amps (7micro amps). So I made a decision to power it all the time. It is now hard wired to one of the wires that has 12vdc all the time. That is the part that is not pretty.
It so happens that the Genny is always drawing power. Small amounts of it to power the clock, receivers for sensing the key, etc. so,I adding another .007 amps seemed like a safe thing. I DID add a way to turn of the sill if I need to. It is a poor man's switch, called an inline fuse. I tucked the fuse in the crease where carpet meets the side wall by the driver left foot.
Here are the pics.....
