PrimoCyp25
I've done door seals in my genesis coupe before, I wired the negative to the door switch and positive into the fuse box, have to check how easy is access to the door switch, might be a better solution
0.007 amps is 7 milli amps not 7 micro amps.
Have Genesis 3.8 2016 will check this out to find out if these is any switched wire running in the sill. Does not need to be at +12v as I can easily use a simple transistor translator to allow the "any switched voltage" to have +12v appear at the collector of the transistor.
Failing this will check what wire(s) carry some reasonable current and then use a current clamp transformer to activate a similar switching transistor.
Stephen
