Remote ESC disable mod.
Genesis Device
4
That's what I don't get...that's what I was refering to when I said things maybe changed during the 2012 build year?? I can tell you that mine was built in May. And I swear by doing the mod, the car did things that would normally slam my face into the steering wheel from the ESC kicking in. I have to run out and get some gas for the mower now, I'll try it again then shoot you a pm...have a couple more questions/suggestions that might help.
MG8
Proud owner of two Genesis vehicles
1,024
616
San Francisco/Las Vegas
looking at the picture above, so it looks there is one extra blue antenna wire coming from the box that is not used as well as the orange?
ltzrok
Sadly, I guess I never read the original post right, because after spending $150.00CDN on the parts from Amazon.ca, this does nothing on the 2012 except for putting the auto parking brake on full, total waste of time and money, my car locked up totally in the driveway and would not move, definitely not a mod for the 2012's
ltzrok
Tried everything in every reply, and NOTHING works in the 2012, why doesn't someone update this forum to include that model year, it was one of the most powerful Gen's they made, and we can't let loose, somebody has to have a mod for this. With my ESC off, I get maybe 5' of spin before the braking kicks in. Pretty sad for a 429hp car by any standards
MG8
1,024
616
so you just did this mod and does not work?
MG8
1,024
616
I can't speak for the U.S. models, but it does nothing except apply the auto park in full and the car won't move.
I just installed mine works perfect. Unleash all 400+hp totally different car without that engine cut feel you get that beast mode feel
edizzle89
90
Columbus, IN
I cant help but to think what is the point of the additional relay? Could you not just use the remote relay and hook the white wire to the other side of the fuse? It's rated for 15 amps which is more then the original fuse. Or am i missing something?
edizzle89
90
Columbus, IN
Nevermind, i realized that the remote relay turning on is made to 'open' the standard relay which acts as the fuse removed. Just using the remote relay would leave it open until you turned on, which is basically the opposite of what it needs to be doing
MG8
1,024
616
OK, 2012 5.0 R-spec - to be or not to be? 😀
Got confused a bit after long thread reading......
i have this mod. works great when disable its like "beast mode" :) 👌
