Bill Georgia
- Dec 31, 2014
- Location
- Peachtree City, GA
Had the Hankook's replaced with the Michelin Primacy MXM4's. Per the recall they are suppose to force balance all 4 tires and set them up on the car in specific location, front right or left back right or left according to how they turn out after the force balancing. I found that the Michelins road fairly bad in comparison but lessening the PSI helped a lot, set at 31PSI @ 60ish degrees out side, and now they feel pretty good all around. I still do get some of that "flat spot" feel for about 6 blocks as I did with the Hankook's, I just keep wondering if it has something to do with the continuously variable dampers that are part of the shocks. They are controlled at all times, if I get the stability control turned off quick enough it seems to go away - hard to verify though.
Yes, continuous variable damping is only on the V8 Ultimate.
