Just finished the install of the Uniq Rigid Collars on my 2013 RSpec. Here is my step by step installation. Pictures were taken with a cell phone. Please excuse the poor quality.
A couple of things to keep in mind.
There are 10 rigid collars. 8 are marked with R (regular), one with F (fine), one is unmarked and has a very slim collar.
- Use the proper tools for the job.
- Torque wrench
- Impact gun
- Impact sockets
- Pry bar
- Socket wrench
- Dead-blow hammer
- Jacks, Jack stands, hydraulic lift, transmission jack, other acceptable vehicle\engine jacking machinery
- This is my method, mileage may vary.
- If you don't want to risk damaging something, don't do it!
- I would rate this as "Intermediate" skills required.
- Remove the three splash guards protecting the transmission and engine components.
- Start from the rear most splash guard.
- Work your way forward until removing the front most splash guard.
- Splash guards are held on by a mixture of regular bolts, slip nuts, and normal metal nuts.
- Find the 6 bolts connecting the front sub-frame.
- Picture of the sub-frame can be found at: http://www.hyundaipartsaccessories.com/auto-parts/2013/hyundai/genesis/5-0-r-spec-trim/5-0l-v8-gas-engine/suspension-cat/suspension-springs-and-related-components-scat/10755705-assy
- Mine were marked with a distinctive pinkish mark.
- Place a sturdy support under the rear portion of the sub-frame.
- Loosen all 6 bolts slightly.
- Make sure not to loosen all the way
- Keep enough support on the sub-frame to hold it in place
- Use the transmission stand/jack to hold the rear portion tight against the uni-body
- Find the rear, driver side bolt holding the sub-frame.
- Remove this bolt.
- Find the unmarked Uniq rigid collar.
- Slide the collar into place (Photo shows a "R" collar in place).
- This is the only collar that will fit into the opening.
- This is the tightest tolerance of all of the mounting points.
- This is the only mounting point where you can not move the sub-frame to install the bolt.
- Replace bolt and hand tighten all the way until the bolt is against the collar.
- Find the rear, passenger side bolt holding the sub-frame.
- Remove this bolt.
- Find the Uniq rigid collar marked with a "F".
- Remove the bolt completely.
- Make sure the rear part of the sub-frame is supported sufficiently.
- Slide the collar into place.
- Release pressure on the jack holding the rear sub-frame up.
- Do this slowly and carefully.
- Double check that the front bolts are not too loose.
- Front bolts need to support the weight of the suspension at this point.
- Move jack/transmission stand to the front of the sub-frame.
- Make sure that the jack is supporting the front of the sub-frame completely.
- Remove and replace the other 4 bolts one by one.
- Find the bolt.
- Place the rigid collar marked with "R" into the hole.
- Hand tighten bolt against the collar.
- It might be necessary to move the sub-frame around to start the bolt.
- It might be necessary to loosen the rear, passenger side bolt slightly to give some play in the sub-frame.
- Use a prying tool in a safe spot.
- Pry again the sub-frame and uni-body.
- Do not pry against the motor, transmission, or any of the electric and hydraulic lines under the car.
- Once all of the front bolts are replaced by hand, tighten each of the bolts.
- Impact the bolts into place.
- Torque the bolts to the required torque settings.
- Double check all 6 bolts.
- Replace the three splash guards in opposite order of how they were removed.
- Locate the 2 forward-most, rear suspension bolts marked with the pinkish mark.
- The suspension is held by the pinkish marked bolt.
- The uni-body the connected with the yellow marked nuts.
- Place a jack/transmission jack on the rear cross member which supports the suspension near to the side where you are working.
- Remove the bolt and nuts holding the bracket in place.
- It might be necessary to remove the splash guards covering the yellow marked nuts.
- Place the collar between the bracket and the mounting point.
- Replace the bracket and bolts/nuts.
- Impact the bolt/nuts into place.
- Torque the bolt/nuts to the required torque settings.
- Find the rear-most, rear suspension bolts marked with the pinkish mark.
- Remove the nut.
- Remove the cupped stopper.
- Place the collar between the stopper and the cross member bushing.
- Replace the stopper and the nut.
- Torque the nut to the required torque settings.
- Repeat the same process for the other side of the vehicle.
- Be sure to support the side of the suspension that you are working on with a jack.
- Double check all torque settings on all of the bolts and nut.
- Take your vehicle in for a 4 wheel alignment!!
