Other week I had the car start shaking fairly badly on a stop light, along with flashing check engine light. Car ended up stalling, although I was able to restart it, without the check engine light but still a rough idle.
Car was smoother but throttled at higher RPMs, however every time it was idle it'd shake fairly badly as a result of the misfire. Wasn't able to actually start it once until I gave slightly depressed the gas when it was starting up. I actually had a headache on the way home, and when I got out of the car, there was an overwhelming gas odor as if I was right next to a puddle of gas.
I've got a scanner tool, and it came up with misfires on cylinders 8 and 4. Had it towed to a local dealer, they determined it was cylinder 8's fuel injector that needed a replacement.
It was replaced with minimal downtime, and the car was good for a few days.
A few days later, same symptoms reoccurred. Scanner tool revealed more misfires (2, 4, 6, 8). It's been in the shop for about a week now, they've replaced another fuel injector and it's still misfiring. They're going to try replacing the drive control module, as they suspect it's gone bad. They're going to need to order it and burn the VIN onto it, and it'll probably take a while.
Any of you have a similar issue on the Tau?
http://i.imgur.com/W7RAbbx.png
I'll keep you guys updated on the progress.
