daddio
- Sep 4, 2018
Just thought I would pass along my "solution" to the auto tilt steering wheel problem so many of us have had.
Once I was able to get the steering wheel in a good position for driving, I looked in the owners manual to see
which fuse controlled the tilt/telescopic feature (page 7-49 for my 2009 Genesis) & found that if I removed the
fuse labeled: 'P/Handle' (drivers side fuse panel), the steering wheel stays in the position I set it at. I don't mind
giving up the auto tilt/easy exit feature to make sure the steering wheel is usable for driving. Also, I keep the fuse
in a safe little plastic container in the car in case I ever need to put it back in to try & adjust the steering wheel.
Hope this helps.
Hope this helps.
