The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Genesis parts & accessories
Advertise with us!
Advertise with us!
Yes, you will rub with 40s I know couple people running 35s and they get slight rub on hard bumps
I wanted some thoughts on as this set up for 14 Genesis stock suspension.
Front 255/40/20 on 9in wheel +34offset
Rear 285/40/20 on 10in wheel +34offset. I want a thicker tire wall for more protection of wheels from potholes/bad roads and a more comfortable ride but I'm scared of rubbing the fender... not sure if 35wall might be better or if I'm good with 40wall tires. Please help if anyone has used 40 on their tires.
You're good.Rub in the front or rear?
I'll be running 20x9 +30 245/40/20 front and rear. Any potential issues? On coils
You're good.
You're fineDoes anyone know if you can run 275/40/19 for the rears on stock suspension with no issues?
2013 3.8L
Thanks! Might as well post the full spec I'm trying to getYou're fine
those wheels look great!2013 R-spec on Ark GTS springs: Aodhan AFF3 20x10.5 +45 on all 4 corners.
Front: 255/35/20 + 20mm spacers
Rear: 275/35/20 + 5mm spacers
Hi where did you get that front bumper splitter?New roller shot heading down to Fayetteville Drag Strip. Best time was 13.3 with much tire slippage.
Better on stocksView attachment 14362View attachment 14365View attachment 14366View attachment 14367View attachment 14367
The wheels are called Marguee wheels 3259 Black Red Extreme Concave Rims 5×114 Front 20x9.5 rears 20x10.5 rears in this picture it's on Michelin pilot sports fronts 255/35/20 on the rear 285/35/20 they only rub during extreme cornering on the off ramp loops now it's riding on Michelin pilot 4s 305/30/20 rear tires stick out rub on uneven payment at 80 mph or faster haven't had a issue at low speed ,haven't cornered extremely and haven't put the wife and daughter in the vehicle yet. I didn't give the offset because, i will be running Brembo calipers front and rear, the wheels rub on the stock calipers had to use a spacer.
