Post your custom wheels
Yes, you will rub with 40s I know couple people running 35s and they get slight rub on hard bumps
I wanted some thoughts on as this set up for 14 Genesis stock suspension.
Front 255/40/20 on 9in wheel +34offset
Rear 285/40/20 on 10in wheel +34offset. I want a thicker tire wall for more protection of wheels from potholes/bad roads and a more comfortable ride but I'm scared of rubbing the fender... not sure if 35wall might be better or if I'm good with 40wall tires. Please help if anyone has used 40 on their tires.
Rub in the front or rear?
I'll be running 20x9 +30 245/40/20 front and rear. Any potential issues? On coils
Does anyone know if you can run 275/40/19 for the rears on stock suspension with no issues?
2013 3.8L
You're fine
Thanks! Might as well post the full spec I'm trying to get
19x8.5 front 19x10 back
245/45/19 front 275/40.19 back
No idea what model wheels these are. 18" made by "FAST" which are supplied by Hyundai in my area.
Previous owner had them on winters. Oh, and don't mind the dark spots on TenGen (rust proofing).
2013 R-spec on Ark GTS springs: Aodhan AFF3 20x10.5 +45 on all 4 corners.
Front: 255/35/20 + 20mm spacers
Rear: 275/35/20 + 5mm spacers
those wheels look great!
2013 R-spec
TSW® - VALENCIA Matte Black (19" x 8", +40 Offset, 5x114.3 Bolt Pattern, 76mm Hub) Front
TSW® - VALENCIA Matte Black (19" x 9.5", +40 Offset, 5x114.3 Bolt Pattern, 76mm Hub) Rear
Front: 245/40/19
Rear: 275/35/19
2011 4.6 - Megan Racing coilovers
Niche Gamma Satin Bronze
20x9 +35 on all 4 corners
Front & Rear: Toyo Extensa Hii - 255/40/20
2013 3.8L
Stock Suspension
Vossen VSF-1 Wheels
Rear 19x10 - Front 19x8.5
Not 100% on the offset
On Firehawk Indy 500's
Rear 275/40/19 - Front 245/45/19
Thanks to everyone who answered my questions!
18”x8.5 18” TSW Sebring’s offset not known tire size 245/45/18”
Have new sized center caps on order.
Also appt set to paint calipers...
New roller shot heading down to Fayetteville Drag Strip. Best time was 13.3 with much tire slippage.
Hi where did you get that front bumper splitter?
  • Like
Reactions: MG8
View attachment 14362View attachment 14365View attachment 14366View attachment 14367View attachment 14367
The wheels are called Marguee wheels 3259 Black Red Extreme Concave Rims 5×114 Front 20x9.5 rears 20x10.5 rears in this picture it's on Michelin pilot sports fronts 255/35/20 on the rear 285/35/20 they only rub during extreme cornering on the off ramp loops now it's riding on Michelin pilot 4s 305/30/20 rear tires stick out rub on uneven payment at 80 mph or faster haven't had a issue at low speed ,haven't cornered extremely and haven't put the wife and daughter in the vehicle yet. I didn't give the offset because, i will be running Brembo calipers front and rear, the wheels rub on the stock calipers had to use a spacer.
Better on stocks
