- Jul 7, 2017
- Location
- Parrish, FL
- Genesis Model Year
- 2018
- Genesis G80
Evidently your dealer is smarter and more customer oriented than mine. I go in and say if I do ABC the coil freezes. They then test it doing XYZ and say it is fine. No, you have to do ABC and the reply is we can't do that only XYZ.I had the same issue. I gave my dealer permission to take my 2018 G80 AWD Ultimate on a 1 hour plus drive. They did and the issue with the AC was duplicated. They replaced the thermistor took the car on another hour plus drive and the issue duplicated itself again. Had the thermistor replaced again. It was driven again with no issue. AC worked fine. Previous two thermistors were sent to GENESIS engineering and deemed faulty. By the way there was no charge to me at all. This was all under warranty.
I did open a case with Genesis but they have not been able to contact anyone at the dealer.
Oh, to show how competent they are they even gave me the number to call Genesis Customer Care. It was the wrong number. They gave me the number for Canada instead of the US.
Thanks for posting this though. They said they replaced a thermistor in another car and it did not fix it. When I said it could have been defective, I got a strange stare but you proved I was correct. My guess is there are many defective one out there and if all you ever do it drive local, you will never have a problem.
You da man! Much appreciated.
