I keep wishing that every poster would add his/her specific vehicle details to their Signature here. It's simple to go into your profile and add that info. Then when you make a comment about your car, we can all see what the hell you are driving! Just click on USER CP in the menu above to add your personal info.
I went out today and started my Genesis and there was no audio at all. I tried changing all modes to get something and the radio was dead.
Without my tunes, I drove to get gas and shut off the engine. When I was finished gassing up and I started the engine, wallah I had tunes back. Does anyone have an explanation for this glitch? 2012 V6
We have a 2012 5.0 Rspec with 7K miles, having the audio mute issues and the surround un-checking issues among other things.... We took it to the Local dealer and were told they had to order parts, not sure what they ordered but i got a call today saying the parts were in. I am waiting to hear from the service writer to decide if i am taking it in. If the parts was the update package from the TSB then i might if it is a new head unit i don't know if i want to go that route yet. Its so frustrating that a global systemic issue is not dealt with better, and if i had known about all the issues we would have bought something else. Makes all the reservations i had about buying a Hyundai seem more realistic. I guess the old adage you get what you pay for comes into play. I sure hope this stuff gets fixed so we can enjoy the car instead of regretti ng buying it.
Timeout, I have had my R Spec about 3mos and have encountered the audio problem surround sound and driver deselect prob such as Economy Driving selected on the steering wheel. I have just now tried your Tech resets and will let you know how they work.If you have the Tech Package, next time you run into this no-audio issue or the voice command is not working, please try this:
Go to ENG menu (by pressing these buttons simultaneously: Disc/AUX, Navi/Menu, Back and the Volume Knob on the DVD player).
Go to the "Software Update" submenu and selet "To full ENG full mode". When you select it, it prompts for a key code.
If you have the old head unit with old NAV maps (2009 and 2010), first try entering ##0324#0704## as key code.
If you have a newer head unit (2011 or later) or upgraded the NAV maps, enter 0324 as key code. Once you enter the code, on the left hand side there will be few more menu items that make up the full engineering mode.
Select "Diagnostics" submenu then select "Reset Component". Select UTA. This should reset the Amplifier. If audio doesn't come back, try resetting the other components.
Please post results here.
Timeout
Thanks for the update. The next time that my system dies I will try your solution.
This is for Timeout. On 6/13 I tried your suggestions for resetting the components. Alas, this did not fix the unchecking of certain settings. I will probably have to go the dealer route sad to say. Thank you anyway.
just experenced this for the 2nd time in a year. Everything audio did not work (radio, nav, bluetooth). I have not restarted yet. Both times it has occurred has been on hot days (for upstate ny)...I dont know if that triggers it? getting a little frustrated as I have had 3 electrical problems(drivers seat, window controls and now this).
