Solution!!!!
It ends up that my LEFT ( driver) turn signal is wired BACKWARDS!!!! and that, being the easy one, was the one I was testing with. Seriously... The 'barrel' of a light is always negative and the bottom of the bulb is always positive. We'll guess what, the left turn signal housing is the opposite of that, but the right one is correct!! So... A little rewiring of the VLED harness and all is good.
As has been said, the right light is a royal PAIN to get to. A brace needs to be removed and the air intake box needs two bolts removed and kind of pushed out of the way, just to get to the round hatch that covers the light housing access.
All wiring, driver, everything fit into the light housing.
This is the left socket that is wired backwards. It took me putting a meter on it to figure it out.
This dhows the modified VLED wiring harness.
The VLED in place. All re remaining harness simply stuffs inside the housing, then replace the round hatch cover.
Lousy shot, but it shows the assembled VLED with the collar, 3 screws, and a medium thickness rubber gasket in place. The kit has several gasket choices, but the medium worked best.
Right side... First remove the crash brace (2 bolts)
Loosen these 2 bolts that hold the air box in place and push it out of the way (twd the engine).
It is tight, but the arrow shows where the hatch is to get into the light housing.
Here's the right side with everything in place, before reinserting the hatch.
End result!
