275 up front? WHOA that sounds like a no bueno...
How wide of a rim will you think you will be running?
9" to 9.5" with a 38 offset.
I'd like to run the same on all four corners.
I could even go 265/35/20 to keep the height equal.
SS
Vast your car looks great!
Do you have a rear side view,also what's the specs on your tint?
wheels: 20x8.5 20x10 Niche M157 Charcoal
offsets: 35mm / 40mm
tires: Nitto NT-555 Front: 245/35/20 Rear: 275/30/20
Vast, I have the same setup but not lowered. Do you feel the fronts need like a 10mm spacer to bring them out flush like the rears?
The fronts have room for a spacer, 10mm may work. The rears are very flush. I love the fitment.
Here is the front:
If you lower your car, make sure the TPMS valve stems are short. Mine kept hitting the rear sway bar damaging the top of valve stem. I had to get barrel straps and relocate the TPMS.
Hey vast. Car looks great. What model coilover did you use? I did not know BC made coilovers me that fit our carsHere is my Rspec on Niche M157s. 20 inch. Lowered on BC Racing Coilovers.
2012 Genesis 5.0
Niche Vicenza - M153 Black Machined with Dark Tint 20x9
Continental Extreme Contact DWS 245 40 20
The car came from the dealer with Michelin Energy Savers - the worst riding, noisiest tires I have ever owned.
