GENROLLER
Hello, I need your help on selecting the correct size tires without any modifications. I was just on the phone with a CarId representative discussing tire sizes for the rims of preference, and I was told the only way that 275/40/20 will fit the rear without rubbing, or the like is to roll out the finder or lower the vehicle. I would like to replace the 245/40/19 (Rspec Contis) with Front 245/40/20 and rear 275/40/20 (Hankook Ventus V12EVO), is this possible without modifications? Also, the representative stated that staggered fitment would not work (front 20 X 8.5 + 35 offset 5 X 114.3 Bolt Pattern, 72.6mm Hub) (rear 20 X 10 + 40 offset 5 X 114.3 Bolt Pattern 72.6mm Hub)
Thanks for your help.
I have 255/35/20 on 9 in wheel in the front & 285/30/20 on 10 in. wheel on Hankook Ventus V12EVO
i switched to General G-Max AS-05 255/35/20 & 275/35/20 doesn't come in a 285 much better ride and handling no rubbing on stock suspension and stock heights though far plan on lowering it a bit
