STEP 7:
Next use some isopropyl alcohol applied to a shop rag to wipe off the Goo Gone or WD40 film.
STEP 8:
Now using two strips of blue painters tape on the top edge, test fit your new KDM "Wings" emblem onto the trunk lid. DO NOT peel the factory adhesive backing off of the "Wings" emblem yet. This is just going to be a test fit for alignment.
As long as your car is parked on a level surface to you can use a bubble/spirit level to confirm that the emblem is level with respect to the car. You can check the car by opening the trunk and placing the level on the trunk floor. If your car itself is not level then you do not use the bubble/spirit level to align the emblem. In this case, use a tape measure to align the emblem by comparing the distance from the wingtip to the lower trunk edge. You should also use the tape measure to confirm side to side positioning.
STEP 9:
Once your emblem is aligned, use the painters tape to tape a perimeter around the wingtips and along the bottom edge of the emblem. You will be using these as your guide when adhering the "Wings" to the trunk. Double check with the tape measure and level after you create the perimeter in case anything has shifted.
STEP 10:
Now take the "Wings" emblem off of the trunk lid and peel off the adhesive backing taking care not to touch the adhesive with your hands as the oils in your fingers will diminish its stickiness.
Carefully apply the emblem onto the trunk using your blue tape perimeter as your guide. I started by applying the right lower edge using both the left wingtip and bottom of the crest as my guide.
Press the emblem on and hold for 20-30 seconds with gentle uniform pressure to ensure a good seal.
STEP 10:
Now peel off the blue painters tape perimeter. Give the emblem and trunk lid a wipe down using the microfiber cloth and detailing spray to remove any fingerprints and you are DONE!!!
ENJOY!
