powerslide
- May 16, 2014
Wings went on without much trouble. Thanks, Motegi. I couldn't find my fishing line so I used some kite string that turned out to be strong enough and thin enough to fit beneath the flying H.
When I went to place the wings, the adhesive grabbed before I was ready for it, but I was close enough that I could push and twist and line it up with my marking tape before it set up. In hind sight, if I were to do it again, I would consider using a water solution to float the emblem into position before pressing it down. I believe they use a similar technique for window films and I have personally used it with other 3M acrylic-based pressure sensitive adhesives. Just a few drops of dawn dish soap mixed in with water and applied via spray bottle should do it. It will give you a few seconds to perfect your positioning and then when you press down on the emblem most of the water is removed. The rest works its way out through evaporation.
