The OFFICIAL Air Suspension Thread
i-Level antenna extension, wheel update and tint
ghicks99, any updates on the antenna extension for the i-Level? I would like more range on mine as well.
Stay tuned, new wheels are going to be finished in two weeks. Been working on getting these since end of January. Size teaser for everyone...
20x10+18 Fronts - 4" Reverse Lips
20x10.5+28 Rears - 4" Reverse Lips
Got my windows tinted with Suntek HP Bronze 40% the other weekend and it turned out great. Pictures don't do it justice, looks more bronze in person.
Whats up guys i just bought a 13 r spec sedan a few months ago. just bagged it this weekend im trying to get the trunk setup dialed in right now but im running aerosport front bags over BC coils and aero house rear bags. accuair elevel. im running into the front clunking noise that was talked about in this thread from the sway bar links has anyone solved this problem with custom links or what? thanks in advance.
her is a photo of my brackets and bags
a few more pic of the setup
Hey man, welcome. Glad to see some action on this thread because it has been a while. Like the way your RLCA mount turned out it looks really good. You making custom mounts for the sensors?
Regarding the clunking noise up front, is yours only on one side or both? Mine used to be on both sides but now only occurs on the passenger side. I did try custom sway bar end links but that did not solve the problem. Eventually took them off and replaced with the OEM ones.
Pretty sure the sound is actually coming from the "pillow ball" mount on the strut. I took the front strut off a few months ago to change the height and lubricated the bearing which made the noise go away for a few weeks. I will lubricate it every now and then but have yet to permanently eliminate the noise. Circled in yellow.
got you that makes sense cause its metal on metal im going to make like a plastic ring to duplicate the oem one to maybe eliminate the sound. yea im going to make some mounts for the elevel sensor got a show this weekend and IFO so maybe during the week or maybe tonight lol who knows i want to deaden the sound a little more from the compressors
I've still never been to a show... maybe one day
I find that the compressor noise isn't that bad when sitting in the car. When the trunk is open they do create a bit of noise with all the copper hardlines. How are you setting up your trunk and lines?
i was planning to push it back as far as possible make a sound box with a lexan viewing window. and then mount my subs on the left and right pocket.
That will look nice. I planned on making a lexan barrier so I could still put stuff in my trunk but a year later I still haven't made one.
UPDATE: One Year Later Review
Seeing that it has been over a year since installing my air suspension I figured it was time to give an update on the setup and my thoughts on the driving experience.
Air Force Suspension
There have been zero issues with the struts/bags other than the popping sound coming from the front right strut. I feel this can be fixed but based on the fact that LeighANidas has the same issue with a different setup, it’s not an Air Force Suspension specific problem. I checked all of the components every six months for loosening hardware, wear and tear, etc. and everything checked out ok.
A few areas of the design that could be improved upon are:
  • The location of dampening force adjustment is located on top of the strut and changed with an allen key. Neither the front nor rear is adjustable after being installed. It would be nice if the adjustment was moved to the bottom of the shock like some other coilovers that I have seen.
  • There is a cutout for the air fitting on the lower portion of the rear bag mount but there is not enough clearance for a wrench to tighten the fitting when the bag is installed on the car. In order to install the fitting the bag had to be off the car and placed the on its side.
  • The upper mount of the rear bag is held into place with set screws. This was a very difficult task having minimal clearance for the allen wrench when tightening these during install.
Accuair e-Level / i-Level
All of the components are of high quality. The eXo mounts made mounting the air compressors, ECU, and VU4 manifold a breeze. The touch pad doesn’t feel cheap and has nice button feel. Response is immediate when changing preset heights and manually changing each corner. The i-Level’s connectivity is perfect some days but hit or miss on others. Having this feature made it easier when setting up ride heights because you can change the height outside of the car while taking your measurements.
Having the ability to adjust ride height has its advantages but sometimes find it to be annoying. I no longer keep the controller on the preset driving height after having some issues with the car exhausting too much air in one corner while trimming and/or driving, (this led to some impromptu fender work with my 4 iron during a photoshoot last weekend). This may be due to the sensor arms not having the full desired travel range but cannot say for sure. They recommend 2.75” but mine is closer to 2.00-2.25”. Currently set my ride height starting with my preset and then dial it in by using bag pressure readings. Having been on air for over a year I know what height my car is by looking at bag pressures and beleive it or not having a full tank or empty tank of gas changes these numbers.
Highly recommend purchasing the Zaetech Digital Pressure Gauge since the e-Level system only monitors ride height. You can hit a preset height but have a large pressure difference between each front bag and/or each rear bag, which I like to call “cross loading” resulting in a not so comfortable ride. When the pressures are closer to one another the ride is very nice.
Driving Impressions
The suspension is a bit softer than stock and does not have much rebound when going over large bumps. Mine is a 2010 with the stiffer/rougher suspension compared to the redesigned suspension on 2012 and up first gens, so I cannot say how it compares to the improved stock suspension. Most people have no idea the car is on air because the ride is so smooth. Not sure if it is just this car or any car where the bag mounts to the lower control arm but this makes for interesting car movement at times. In certain situations when driving over wet lines in the road or when the roads are starting to get icy it feels like it takes a split second for the movement to be translated from the RLCA through the bag into the upper mount, sort of like a sideways whiplash effect. This movement occurs on both stock and aftermarket wheels.
Overall I am very pleased with bypassing coilovers and going straight to air suspension. Best thing is that the car looks perfect when aired out.
yea just took a road trip this weekend and i definitely need some type of barrier. had so item resting against the compressors.
Re: UPDATE: One Year Later Review
Driving Impressions
when you air out does your tire rub the qtr in the rear?
Also how close if your front rim lip to the fender. im trying to dial in offsets so i can build some wheels definitely want to go 20s cause i test fit my 19s they look to small. i want the front wheel lip to kiss the front fender, judging by your rear offset your rear is poking a bit correct and if you air out all the way it will touch the Qtr?
are you maxed out in the front for as low as you can go?
i aired all the way out on a 19x10.5 but i had a 265 35 on the front and the tire cannot travel any further it hits the apron of the fender well. i would like 20s but i want the rim lip level with the fender i know i know im picky haha
Fitment questions.
Yes. Needs to be pulled about 6mm to clear.
Wheels aren't on right now so I cant measure for you but its very close, a mm or two would be my guess. Keep in mind I had the front fenders slightly rolled so I could drive with about 25.5-26.0" off clearance from ground to top of fender lip. Pic when test fitting to give you an idea.
Slight poke but am running 2.0° of camber. You can get around 3.3-3.5° with the factory eccentric bolt which might be enough for it to tuck but can't say for sure. My rear offsets are slightly less aggressive than VipdOut's, 10.5+28 compared to 10.5+25, and his tuck with a slight fender pull. Pic when test fitting to give you an idea, had camber maxed out when I took this picture. Also not a 100% representation of fitment since I jacked up the wheel with the car on jack stands instead of lowering the car and wheels onto wooden blocks.
Yes, upper control arms bottom out on access hole in engine bay, have some nice indents now. Plan enlarging this hole once my Prada Side covers get here and will cover up the access hole.
No its a game of mm. I thought mine would fit perfectly without rolling/pulling the rears but was slightly off. Doesn't help that there aren't many setups to compare either.
Re: Fitment questions.
Vipdout is actaully selling his wheels right now 20x9.5 +18 front and 20x10.5 +12 rear i like his car alot but to me it looks like it can go lower in the front i think his just look ssuper slammed cause of the lip. but if you look at the wheel to fender fitment it needs moar low haha. where did you order those prada side covers? i would like some to cover up my huge holes haha. when i aired out on these 19s the rocker molding deflector was draggin on the floor im afraid i cannot achieve this with 20's also i had a 265 35 19 in the front im thinking maybe with a 20 and a more aggresive stretch i can get this thing just as low as i had it.
The specs I put up were for his old Work Wheels, I couldn't remember the AME specs off the top of my head. The lip does restrict how low the front can go I have a My Ride Version 2 I am putting back together, you can see it sits about 1.5" lower than the factory bumper. I think you could get it to be that low on 20's without a front lip and the right stretch. My fronts aren't really stretched at all (245 on a 10").
Prada Cover Part Numbers:
BH 29310-3M000 - LH Side Cover
BH 29320-3M000 - RH Side Cover
29240 3F450 - Engine Cover
Sweet good to know im going to mess with my trunk setup this weekend and hook up elevel.
good to know i called my hyundai dealer and he couldnt locate those numbers is there a website you used to order them?
Cover part numbers
Yeah about those KDM part numbers... any KDM part number won't come up in the American system since they have access to US parts only. I have a few sources but I got these particular pieces from KDMMotors. Cost me $82 shipped for the two pieces. Shipping is a killer from Korea, 11 bucks a piece but 60 to ship. Just send them an e-mail, you wont find these parts listed on their site. For future reference they can get you just about anything from Korea.
For some reason these part numbers don't show up in fourgreen's website but I know those are correct numbers. Instagram user Nevertroll was nice enough to send me pics of the underside of each cover because I couldn't find the part number online.
Re: Cover part numbers
sweet thank you. gotta get these wheels asap haha. ill shoot some photos of the trunk setup hopefully get it done this weekend
Trunk Setup
Looking forward to seeing what you come up with. So many different ways to go about it.
Re: Trunk Setup
Whats your front offset? i was thinking some weds 20x9.5 +14 and 20x10.5 +18 i want to poke like the whips and chocolate genesis from canada but i want my front to poke more than his. do you know which car i am referring to?
