The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Genesis parts & accessories
Advertise with us!
Advertise with us!
Second, the back up camera quality. I am still trying to see if my camera is just faulty or the camera is just very low quality.
I may have to check out a similar car to see if the camera is really bad or not. My 2014 KIA Optima SXL had a very crisp rear view image. My Genesis image looks washed out and fuzzy.While not HD, the camera is decent. Take a look at one on the dealer lot to compare. You may have a problem.
A further dislike, and a borderline dangerous aspect involving that pesky park brake , if you engage the park brake with no set belt on, it won't disengage when you select D and press the gas pedal.
Not sure what potential calamity this safety feature will prevent but I sure as **** know what annoyance it
causes to other road users at traffic lights on an up hill when I can't move off.
Yes, I don't use the auto-hold feature much at all to be honest.
I wonder if the auto-hold works on all four wheels or just the rear two ?
I am not 100% certain ,but i think that the auto hold only operate the rear parking brake motors on the rear wheels. It worked that way on my old 2014 KIA Optima with EPB w/auto hold.Yes, I don't use the auto-hold feature much at all to be honest.
From my experience I would say all four. I love auto hold. I just wish I didn’t have to enable every time I start the car. I would prefer it would remember that it was enabled.Yes, I don't use the auto-hold feature much at all to be honest.
My cooled driver seat did the same thing. It would turn on for a few minutes and then shutoff until I turn off the car; button would not work. It happened because the rubber tube under the seat that runs up the back of the seat to the cushion vents came loose from the blower. I guess the blower has a fail safe that shuts it down for it not to burn itself out when the tubing come loose or is torn.Are the cooled seats on a timer ?
I find they are effective for 4-5 mins then they seem to turn themselves off.
The seat back is easy to remove. Just pull it straight up and it comes right off.
By "seat back", you mean the whole back on which you rest comes off?
Here is the seat back and seat cooler hose. Just pull it up. I took mine off in two seconds to take this picture.By "seat back", you mean the whole back on which you rest comes off?
No problem. A picture usually helps more than trying to explain it in words most of the time.Thanks! The pictures helped!
